Sponsored by: CARiD
Old Apr 28, 2016, 06:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Interior Guides
Print Wikipost
99 T/a Check Engine Light Resest
Old Oct 9, 2007 | 04:02 PM
IMOTEPHT's Avatar
Default 99 T/a Check Engine Light Resest
How do I reset my service engine soon light off on a 1999 Trans Am?
Old Oct 9, 2007 | 04:22 PM
BIG_MIKE2005's Avatar
Fix the problem causing it.
Have it scanned & fix it is the only way I know of. If you recently did a mod that caused it your tuner should be able to turn it off when you get some edits.
Old Oct 9, 2007 | 04:38 PM
IMOTEPHT's Avatar
It was the EGR but I fixed it so now I need to know how to reset it? Can I just unplug the battery for awhile or do I have to reset it with a OBD-2 code reader?
Old Oct 9, 2007 | 04:40 PM
Well when we removed my EGR for the LT's the light wouldn't go off until I had my tuner turn the codes off.
Old Oct 9, 2007 | 04:44 PM
2001NBMZ28's Avatar
PCM Reset
Turn key on, don't start car
Pull PCM BATT and PCM IGN fuses in engine compartment
Wait 5-10 min
Turn ignition off
Replace fuses
BTW, idle will be grumpy after resetting it this way for a few minutes until it relearns.
Old Oct 9, 2007 | 04:55 PM
IMOTEPHT's Avatar
Ok cool!
