Security light at startup=no igniton
What causes this and how do I fix it because it has happened a few times now and is getting really annoying as I have to leave the car for 5-10min then retry and sometimes its fine, sometimes the whole process has to be redone.
Thanks,
Jason
It just pisses me off that its completely random so I never know why it happens so as to avoid it if thats even possible.
Once you remove the connector you can take it to a work bench to solder in your resistors. Just remember the resistors have to be in series, or one after the other, and their values must add up to the value in your key pellet. The only real difficulty here is the wires are small, either 18ga or 20ga.
connector--wire1--resistor--resistor--wire2--connector...
I'd measure the key pellet and pick up your resistors first. You'll only need a multimeter for that. Then 7mm socket (2 bolts), #2 phillips (2 screws) for the panel under the steering column. Wire cutters/strippers, soldering iron, solder for the resistors and wiring. Heatshrink or electrical tape for cover.
If you leave enough wire (the 2 wires in the orange sleeve) under the dash, you can reconnect the connector without the resistors to put it back to stock config.
