need help figuring out why I'm lean!
Check to see if Mass Airflow sensor is dirty, clean it
Check for vacuum leaks
Replace front o2's
Check fuel pressure
Soo what's the easiest way to go about all this? Any way to "check the o2's? Where is the most likely place to have a vacuum leak? And is it easy to check my fuel pressure? What pressure is it supposed to be at?
PS - my car isnt throwing any codes, and it feels strong and fine... idles normal as well
Replace front o2's
Check fuel pressure
