Sponsored by: CARiD
LS1 Oil leaks
Old Oct 27, 2007 | 07:30 AM
LS1MUNN's Avatar
Angry LS1 Oil leaks
I have a 99 B4C A4, it seems to bee leaking oil from the oil pan gasket. I have been under the car looking and it seems to be dry all over above the oil pan, and wet EVERYWHERE below. Front to back and both sides. Does anyone know if the oil pan be removed and the gasket replaced with the engine in the car? Has anybody ever tried this? All the bolts are accessible, It just looks like there may not be enough room to swing the pan down and clear the sump and the bell housing. Any Ideas?
Old Oct 27, 2007 | 05:49 PM
dependonauto's Avatar
You have to losen the engine cradle and raise engine. Check the oil pressure sending unit as they are prone to leak.
Old Oct 30, 2007 | 08:26 AM
mmorellicamaross's Avatar
Default oil leaks
were is the oil pressure sending unit located?
Old Oct 30, 2007 | 12:20 PM
Tuffguy610's Avatar
Unfortunately it is located on the back side of your intake manifold. Search for pictures of an intake manifold for reference.
Old Oct 30, 2007 | 01:16 PM
INMY01TA's Avatar
Ever had the cam out? Front cover off?
Old Oct 31, 2007 | 09:17 AM
Default oil leaks
has anybody changed an oil pressure sending unit? if yes what is the procedure.
Old Nov 4, 2007 | 07:28 AM
LS1MUNN's Avatar
No I havent, I want to just pull the motor/trans, and rebuild em this winter, I just dont know if Ill have the $$. I at least want to put on a new oil pump, timing set and cam. But my tranny is a bit loose. I'd really like to go through it.
