pesky oil leak
pesky oil leak
I have a 2001 camaro ss ls1 that is vortec supercharged that has an oil leak that I can not identify. I change all the oil feed and drain lines, I had the supercharger rebuilt with new seals and bearings. The Harmonic balancer bolt was loose and I thighting it but I can't seem to get it to hold, I tried thread locker but the bolt won't hold, can the oil be coming from here? could it be coming from the oil pressure sending unit and if so were is that located? it seems to be coming down were the alternator is on the left side of the motor when I get under the car I can't see were it is leaking from but then I drive it and there is oil on that side of the motor. any suggestions????
