Another #8 Spark Plug Question.
I've tried to go from underneath on my '98 car with stock manifolds & cats. I don't see how it's possibile.
I used a plug socket, with a 1 inch extension, then a swivel extension, another short extension, then the actual ratchet. I found that the ratchet was too far down for me to get any leverage on it.... So I looked around my garage for some ideas... found a special wrench for tightening the chain on a chain saw. Its sorta looks like a tube (about 1/2 inch in diameter, and 4 inches long) with a metal rod on coming out of it. Kind of in an 'L' shape with the bottom of the L being the tube part. Still with me??? I slipped that on the end of the ratchet and it took me maybe 10 mins to change #8. The chain saw tool gave me the leverage I needed in the tight spot.
The only problem with this is that you will have no idea what kind of torque you are putting on the plug. I went on the side of being too light, and had too do it all over again two weeks later when it came loose.
The hex nut of the plug that's screwed into the head you are not going to hurt, so just break the whole plug tip off and get it out of the way. Reclaim your spark plug socket grommet if that was left on the plug. when removing the plugs take the grommet out of the spark plug socket.
I had a 99 camaro, and now have an 02. I've always done #8 (passenger side rear) from the top. If the plug has never been out, you might need a breaker bar for some leverage since you are on such and awkard reach angle to begin with.
All I've ever needed to change all 8 plugs was:
3/8" standard size ratchet (craftsman)
stubby 1.5" extension and normal 3" extension in 3/8" size
standard spark plug socket,
and about an 8" cut piece of 3/4" black pipe from home depot that I use as a breaker bar, get the thinnest piece that'll still fit over your rachet. I think when I've done #8 i've used the 1.5" stubby extension or no extension.
I take all the coil packs off, and i am able to position the ratchet and have maybe 30 deg of rotation possible, use the little breaker bar extension for leverage and the plug should come right out. I think it's harder getting the new plug for #8 threaded, then use the grommet in the spark plug socket and a 1.5" extension to give you the reach from the top.
A buddy is going to help me Sunday tackle this. A small piece of the ceramic on #8 is broken but the wire still attached to it and the car runs fine and on all 8 cylinders, but I have been hearing a small tick coming from back near #8 so I take it that it must need to come out asap. Either way the buddy going to help me has some sorta spark plug socket that is much smaller than normal for race car headers with little room to access them... I will keep this posted for Sunday when I get this problem fixed. Thanks
http://www.camaroz28.com/forums/showthread.php?t=458308
Using this method, I didn't even have to actually touch the plug, just had to get the right angle & socket/adapter length so the socket would naturally fall in place. You can do the same with a swivel ratchet and the right extension. Just might have to use a cheater bar on the ratchet to help break it loose.
As far as the plug feeling wierd, sounds like you broke the ceramic and it's cocked to the side. The ticking is probably spark arcing to ground past the crack in the ceramic. In your place, I'd finish busting it or use a screwdriver to straighten it enough so I could get the socket on the plug hex. If you weren't on the other side of Texas I'd help you out with my tool combo, with you supplying the Buds if course.
Come to find out, the autozone crap spark plug socket (5/8th) must be too big for #8 so with his special small socket from snap-on we got it off the 1st try. She now runs so much better and im glad I did not cause any damage like i suspected. Stock LS1 Power
!! So this being my 1st spark plug change on a LS1, I now know how to do it!
Thanks to those who helped in the thread!
