Sponsored by: CARiD
Weird Headlamp Issue ..... HELP PLZ!
Old Nov 3, 2007 | 06:24 PM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
Default Weird Headlamp Issue ..... HELP PLZ!
Weird headlight issue. My Low beam lights don't work!!
hear are the facts:
-Both fog lamps work
-Both High beams work
-Both low-beam light fuses are still good. (15amp)
-Both lamp-motors still lift
So most of you are thinking what I was originally thinking! That I need new lamps. Derda! der! BUT,.. this is why I find my problem weird. Both went out AT THE SAME TIME,... AND those lamps are both not even a full year old.
What do you all think? Is it JUST me, ..because I thought it wasn't common for both lamps to take a crap at the same time.... OR could it be something else?
Old Nov 4, 2007 | 07:50 PM
Anyone?....
Old Nov 5, 2007 | 01:57 AM
wow,... no one?!!
Old Nov 5, 2007 | 07:33 AM
raven_450's Avatar
seems like you answered your own question with it being both low beams died. although it is wierd for both to go out at the same time its not impossible. I would check to see if there is something causing this problem though since u said they are under a year old. Such as excess vibration on the low beam brackets.
Old Nov 5, 2007 | 06:58 PM
johnnydi's Avatar
I don't know but I didn't want you to think you were out here alone I'm waiting for something like that to happen to mine. They seem to go off and back on for only a split second with no rhyme or reason to it. Doesn't happen when I hit a bump or when it's raining, only when it feels like it. I'm guessing a loose connection or a wire harness problem. John.
Old Nov 6, 2007 | 12:32 AM
See,... thats the obviouse fix but I wanted see if anyone could offer another point of view on WHAT ELSE it could possibly be!
ANYONE ELSE HAVE ANY THOUGHTS?!!!
Old Nov 6, 2007 | 01:19 AM
chromeplated500's Avatar
relay? interior switch? ground? wiring? thats what i came up with... I would prolly see if i get any power to the lights right at the lights... to see if your getting power there if your not... replace your bulbs and cuss a little.
Old Nov 6, 2007 | 03:37 PM
Thanx! That actually helps. I'll pop on by my buddy's shop and check it out there.
