another a/c fan issue
then blow the fan dry, run it for a few minutes and see if its better.
If its still noisy,repeat the procedure,hopefully by then it will be sorted.
For good measure, use wd 40 with the nozzel,and blast around the bearing location or close as you can muster, so the lubricant can eventually run into the bearing.
