Sponsored by: CARiD
Acceleration problem
Old Dec 15, 2007 | 10:12 PM
hlaalu's Avatar
Question Acceleration problem
I have a problem with my acceleration that I have not figured out yet. For example, when I am in 5th gear cruising at 50mph-ish and I floor the pedal, the rpms will shoot up for a few seconds, and then come down and start going up. This happens in all the gears when I floor it. When the rpms are 2750+ this problem doesn’t really happen. I’ve had the intake checked out, that is fine. I bought some fuel injector cleaner so I’ll see how that is. I’m hoping its not my clutch. Anyone have any ideas? Thanks.
Old Dec 15, 2007 | 11:25 PM
CranMaro99's Avatar
Probably your clutch.
Old Dec 16, 2007 | 03:38 AM
hlaalu's Avatar
When does a clutch usually go bad? The car has 66k miles. I remember my v6 camaro's clutch lasted untill about 90k.
Old Dec 16, 2007 | 09:58 AM
autotrix's Avatar
Closed ex-Sponsor Account
Its all in how you drive your car, I believe its your clutch as well.
Old Dec 16, 2007 | 10:50 AM
hlaalu's Avatar
Yea the more I read the more I think clutch..
Old Dec 17, 2007 | 11:22 AM
hlaalu's Avatar
Do I have to replace all the pieces or do I just have to replace the clutch disc?
Old Dec 17, 2007 | 11:47 AM
87gnx's Avatar
Clutch disc, and throw out bearing will probably get you by (unless the disc is scored).
Old Dec 17, 2007 | 02:52 PM
hlaalu's Avatar
Thanks for the reply. Whats the max amount of horsepower a stock clutch can handle?
Old Dec 17, 2007 | 06:14 PM
autotrix's Avatar
Depending on your mileage I would consider a slave as well- because if it leaks it could take out your new clutch. my .02
I think a stock clutch can hold 350hp( at the motor ), do a search to find out more questions you might have, there is plenty of great clutch info here on tech.
