Replacing Windshield Wiper (Entire Unit)
Also, how difficult is it to remove and replace the plastic piece below the wipers and between the opening of the hood and at the bottom of the window? What is the actual name of this piece?
If you mean the motor, well that is a pain in the *** to remove and even worse getting it back in, but it is possible. What is wrong with it anyway?
The other day I had been cleaning around the wipers. I then went to the raise the hood to clean around the engine. I accidentally left the passengers side wipe standing up. So, when I raised the hood, it made contact with the wiper until I noticed it.
After looking, I realized the arm wasn't in the correct position. I think raising the hood against the wiper arm warped the slim piece in the middle, placing the blade in thw wrong position. It is now sitting up on the plastic piece under the windshield instead up against the stoppers.
It also popped the plastic out in the little "bowl" down around the bottom of the wiper arm. Hence, why I was curious how difficult it is to remove this piece from under the windshield and replace it with another. I don't even know the name of the party however.
Any help would be appreciated.
