Supercharger-like sound from Hell!!!
I've tried the following with no changes..(Still making the sound)
removed oil cap and ran
Ensured all pcv lines are connected to proper location and no leaking
checked for vacuum leak (none)
Triple checked intake manifold torque specs (89in lbs)
Ran it with the air lid disconnected (just MAF connected to throttle body)
Changed oil 2x (no metal shavings or anything strange came out)
Removed throttle body and cleaned
Cleaned the IAC and made sure O-ring wasnt damaged
Rev'd the engine with the clutch in and out
I'm running the factory Throttle Body
Someone mentioned it could be the factory hole in the OE throttle body blade... I doubt it, but just incase: Anybody getting this noise with an aftermarket throttle body with a solid blade/butterfly?
I'm running out of ideas, silly because it runs great
What is the condition of your ATF - color and smell please? It should be cherry red in color and should not smell burnt. Any ATF contamination in your antifreeze/radiator?
