Sponsored by: CARiD
2000 Camaro Headlight Module Alignment Problem
Old Jan 18, 2008 | 07:53 PM
anne2000's Avatar
Default 2000 Camaro Headlight Module Alignment Problem
I recently had to replace my turn-signal/running light and in order to do that I had to remove the headlight unit. All went well until I put back the module. The lower tabs fit in but the light module is slightly angled toward the center of the car. Is it possible to loosen the large bracket that holds th.e lower tabs and adjust it? I can get it the way it's supposed to be but then the tabs come out and are behind the large bracket. I hope I'm explaining this so someone understands
