Window motor repaired!
The carbons and the rotor were covered by a sticky compound
I cleaned up everything, made the rotor shine wit some fine scotch brite, cleaned the spaces between the copper blades on the rotor and put a dab of grease on the bearing surface.
It's a little tricky to put the parts together because the carbons have to be kept on place while you put back the plastic cap.
The motor turns now noiseless and the window is really fast!
Time to "repaire" it: 1 hour if you are slow.
The car is a 98 Trans Am with 85'000 miles on it and this is the original window motor.
Here a good explaination about how remove the motor
http://shbox.com/page/windowmotor.html
Greetings
Stefano
I think every electrical part in the motor has to be cleaned. The oxyde has to be removed from the rotor too. So it's not just a carbon issue.
The window is now as fast as new, but I can't say if it's the refreshed motor or the new grease I put in the rails... maybe all together.
It would be good to put new grease in the gear case, but you can't open it widhout making damages.
Scheduled maintence: I would say wait until the motor is dead and then open it.
By the way: be very careful while drilling the holes in the door: it's built on fiberglass and its dust is really nasty (it badly itches on your hands!) so better use latex gloves.
Is there any way to replace a motor without having to drill holes? Would a professional shop also have to drill holes?
You can remove the complete assembly... but then you also need to readjust the window position! Not so easy, I guess.
This of drilling the holes takes 5 minutes, look at the pics on the link I posted: it shows the exact position of the holes. Just work with latex glowes or the fiberglass particles will bother you for a while.
I looked over the pictures showing the holes, and I have no doubt it's an easy and quick job. I'm just worried that having holes there might cause problems down the road, such as liquid or condensation (from heaters) passage into the motor compartment.
