Sponsored by: CARiD
how to get t/a front bumper off!
Old Jan 25, 2008 | 04:06 PM
slayerized6's Avatar
Default how to get t/a front bumper off!
i need to get my t/a off before it gets dark! i removed 3 pins from the top by the radiator, 3 from the bottom, 4 bolts on drivers side and 4 bolts on pass. side, all on the bottom. 2 bolts each by the drl's. what else to i need to remove, its stuck by where the fender meets the bumper
Old Jan 25, 2008 | 05:12 PM
anyone?
Old Jan 25, 2008 | 05:18 PM
chuckyt1's Avatar
Don't if it's the same as a Camaro but did you get the 3 at the seem by the fender and bumper cover?
Old Jan 25, 2008 | 05:20 PM
i got 2 out, but it looks like theres a 3rd one on a different location. its not a bolt and its not a push pin, i have no clue what it is
Old Jan 25, 2008 | 05:32 PM
chuckyt1's Avatar
Here's a link to some pics of an LT1. Might help. Those 3 that are on the fender always are a pita cuz they rust and break off half the time...
http://www.bfranker.badz28.com/fbody...er_removal.htm
Old Jan 25, 2008 | 05:53 PM
it has to be different on the trans am. i already saw pics of the camaro bumper and its got 3 screws in a row, but the t/a only has 2. i got to remove 2 bolts tomorrow and hopefully it will come out alright. but if anyone has expeiernce taking off the t/a bumper, let me know.
Old Jan 26, 2008 | 10:17 PM
loser98's Avatar
by the sides where it meets the fender there are 2 studs that go through the fender and bumper then going horizontal there is 1 10mm might need a light to see it. There are 2 plastic shields that bolt to the bottom of the bumper also. Also after you get the bolts out you have to slide the bumper down off them studs. The rest I think you have. So 6 plugs 4 nuts 2 bolts then all the 10's for them 2 shields under it.
Old Jan 27, 2008 | 04:35 PM
joshp14's Avatar
Did you put the headlights up and get the one that goes in from the front near the headlight opening? This pic may help:
Attached Thumbnails how to get t/a front bumper off!-296252.gif
