55k 2002 B4c runs perfect need advice...
RPO codes as requested
More Pics tomorrow ....
it's late but I promised the picture is below
A31
Window Power Operated, All Doors
A90
Lock Control Rr Cmpt Lid, Rem Cont Elec Release
Ag1
Adjuster Frt St Power, Multi-directional, Driver
Ak5
Restraint System Seat, Inflatable, Driver & Pass
Ar9
Seat Frt Bkt, Deluxe
Au3
Lock Control Side Dr, Elec
B4c
Sales Special Service Police Pkg
B84
Molding B/s Exterior
Bbs
**** Shifter Hurst
C49
Defogger Rr Window, Electric
C60
Hvac System Air Conditioner Frt, Man Controls
De9
Sunshade Rr Passenger Compartment
Dg7
Mirror O/s Lh & Rh, Remote Control, Electric, Color
Fe2
Suspension System Ride, Handling
G80
Axle Positraction Limited Slip
Gu6
Axle Rear 3.42 Ratio
Ip2
Trim Interior Design (p2)
J65
Brake System Pwr, Frt & Rr Disc
K34
Cruise Control Automatic, Electronic
K43
Generator 102 Amp
Ls1
Engine Gas, 8 Cyl, 5.7l, Sfi, Alum, Gm
Mm6
Transmission Man 6 Spd, Tremec, 85mm, 2.66 1st, 0.50 6th, O/d
Nf7
Emission System Federal, Nlev
Nk3
Steering Wheel Sport, Soft Rim, Simulated Leather
Pw7
Wheel 16 X 8, Aluminum, Styled
Slm
Sales Processing Stock Orders
Ste
Plant Code St Therese, Pq, Canada
Tb2
Fenders Frt
192
Trim Combination Leather, Ebony (2) (00)
1sp
Package Option 14
1sz
Discount Option Package
41q
Molding Color Black (91)
41u
Primary Color Exterior, Black (02)
6bs
Component Frt Lh Computer Sel Susp (6bs)
7bs
Component Frt Rh Computer Sel Susp (7bs)
8tj
Component Rr Lh Computer Sel Susp (8tj)
9tj
Component Rr Rh Computer Sel Susp (9tj)
T96
Lamp Fog, Frt
U73
Antenna Fixed , Radio
Ua6
Theft Deterent Sys
Ub3
Cluster Inst, Oil, Cool Temp, Volts, Trip Odom, Tach
Un0
Radio Am/fm Stereo, Seek/scan, Cd, Auto Tone, Clock, Etr
Uq0
Speaker System 4, Dual Frt Dr Mtd, Dual Std Rge Qtr/shelf
V12
Cooling System Power Steering, Fluid
V73
Vehicle Statement Usa/canada
Vm3
Label Information Consumer, Contains Bpr Imp Standard For Frt 5 Mph & Rr 5 Mph
192
Trim Combination, Leather, Black (2) (91 )
41q
Molding Color, Black (91)
41u
Primary Color, Exterior, Black
192
41q
41u
A31
A90
Ag1
Ak5
Ar9
Au3
B4c
B84
Bbs
**** Shifter Hurst
C49
C60
De9
Dg7
Fe2
G80
Gu6
Ip2
J65
K34
K43
Generator 102 Amp
Ls1
Mm6
Nf7
Nk3
Pw7
Slm
Ste
Tb2
Fenders Frt
192
1sp
Package Option 14
1sz
41q
41u
6bs
7bs
8tj
9tj
T96
Lamp Fog, Frt
U73
Ua6
Theft Deterent Sys
Ub3
Un0
Uq0
V12
V73
Vm3
192
41q
41u
192
41q
41u
Here it is hidden behind my german junk .....
I posted this in the post your garage ....
I have a few V8 machines but the Camaro is
something those of us that understand is somehow much much better .. OK make that F body !
The Draw to this b4c is the fact that not to many people have a clue as to what it is
The Draw to that 1992 500E you see is the same it is very unique and a few folks notice (usually think it's a kit )
http://www.mercedesshop.com/500e.htm for more info
Doing Juices, Plug and wires for sure
Brakes and new rotors for sure
Thinking of doing the dynamat quieting thing as it is really loud (?)
Clutch is good thanks for the support
Shocks ? how long they good for? they are clean and shiney no issues so far!
I really appreciate all the suggestions
LB
LB
I have the same car, but in black. I think they only made 62 in black. My car is so stripped it does'nt even have a trunk button. As far as maintenance, try sea foam and an injector cleaning service. Other than normal maintenance, if you are still getting good fuel mileage with no issues, leave it alone. If it's not broke don't fix it.
It just has b4c and 6spd; nothing else. I live in Sulphur and work in Lake Charles. If you are going to be in town this Saturday, we are having a big get together. The first Sat of every month.
Seafoam is raved about I use techron and a Pic
I read all about the love of seafoam,
But I didn't have anyone suggest that in this thread. I use Techron to keep injectors clean
Here is the car in Colorado ..tt2's goodyear f1 315's on the rear
I have the stock wheels in the garage
Gunna put her on the lift Tuesday
Many had asked for Pics so here are 3
Here are three pics from yesterday
I have TT2 also for the car shoud with F1 335 goodyears
As you see it's a B4C with a few mods all able to be put back to stock as I have kept all stock hdw
Did Plugs and Juices, brakes and rotors, cars almost perfect but ....
My shifter is loud (hurst) is the any way to get it not to buzz/rattle
The Rear End is very Loud too ...thoughts ot live with it
Thanks for the help
L
Thanks for the help
L
What do you mean "rear end is loud."? Is it loud when turning? Like groaning/whining? Does it make noise when you're cruising down the road? (Put the car in neutral at cruising speed with the windows up)
Makes Noise while rolling
fine in turns just very loud when rolling has been for many miles is not getting worse just tired of the noise.
It like a constant grind but I changed the fluid and no large issues were found
