Sponsored by: CARiD
Anyone havea squeek in the trunk
Old Feb 3, 2008 | 02:16 AM
NightRider2000's Avatar
Default Anyone havea squeek in the trunk
My car idles real rough and after hard acceleration my rear trunk makes noise. I am wondering if anyone knows why.
Old Feb 3, 2008 | 10:06 AM
Formula413's Avatar
The first thing to check for a squeek in the back would be the jack and spare tire. I also had an issue with my amp making noise. The amp is above the right rear wheel well behind a panel, make sure it's on tight and not vibrating.
For a rough idle the first thing I would look into is a seafoam treatment, see the sticky in this forum for more info.
Old Feb 3, 2008 | 02:49 PM
blkbird's Avatar
Yes!!! I cant find it and its driving me nuts!!! Had it for a couple of years already.
Old Feb 3, 2008 | 02:50 PM
z28berryhill's Avatar
spare tire !!! i think
Old Feb 3, 2008 | 03:48 PM
I haven't taken anything apart but I am suspect of the trunk hatch. But you guys might be on to something. I am going to take apart the back and find out what the hell that noise is.
Old Feb 3, 2008 | 03:55 PM
The rough idle is from my big *** cam.lol Actually that bitch shakes a lot. I wasn't sure what people meant by street or track setup but now I know. I like it but it's tough to drive slow. The car wants to move.
Old Feb 3, 2008 | 06:44 PM
RedRocketZ28's Avatar
Join the club dude. Every fbody that I have owned has squeaked. It sucks but I have gotten use to it.
Old Feb 4, 2008 | 08:55 AM
Vrbas's Avatar
Squeaks over speed bumps, really annoying.
Old Feb 4, 2008 | 10:48 AM
01Z28M6's Avatar
Mine started squeaking after I added LCA relocation brackets and an adjustable panhard rod. I can't determine where the noise is coming from.
Old Feb 4, 2008 | 11:40 AM
PewterScreaminMach's Avatar
I was going to ask if any of you have aftermarket lower control arms. The polyurethane bushings that typically come with these parts have a tendency to squeak, especially if not lubed up and greased enough. Just some info for you.
Old Feb 4, 2008 | 12:41 PM
2002ssls1's Avatar
I had a squeak in my trunk area too. I tore everything out of the area to find I still had a squeak. It ended up being a bolt that held on the exhaust was backing out allowing the exhaust bracket to move. I tightened the bolt with a little loctite and it as good as new. No more annoying squeak.
Old Feb 4, 2008 | 03:17 PM
TXZ28LS1's Avatar
im having a squeak as well. i think its my catback as well!!
Old Feb 4, 2008 | 04:26 PM
blkbird's Avatar
HAHAHAHA!!!! Didnt you tighten the crap out of it when we did your headers???
Old Feb 6, 2008 | 03:26 PM
troopercar's Avatar
Heat shields
