Sponsored by: CARiD
Need Help!! Fan Only Blows On High
Old Feb 3, 2008 | 12:17 PM
themailman's Avatar
Default Need Help!! Fan Only Blows On High
My wifes 2003 Suburban fan only blows with the setting on 5 (the highest setting). Other than that, everything seems to be OK. Any ideas would be greatly appreciated. Thanks.
Old Feb 3, 2008 | 01:51 PM
joshp14's Avatar
More than likely a blower motor resistor. Price will depend on if you have automatic or manual HVAC controls. Pretty easy to change.
Old Feb 3, 2008 | 02:09 PM
themailman's Avatar
The controls for the HVAC are manual. Any info on changing the resistor? Thanks, joshp14.
Old Feb 4, 2008 | 05:36 PM
joshp14's Avatar
Pretty easy, pull down the access cover on passenger side under dash, unplug the resistor, remove the bolts, install new resistor and install everything you took off. IIRC, the resistor bolts are 5.5mm.
Old Feb 4, 2008 | 07:04 PM
themailman's Avatar
Thanks Joshp14 for all your help. You are a true Tech Guru.
