3 week old t/a
but if you don;t mind me asking... WTF are you doing taking that car to a dealer?
it's true. i can't say i've priced the bearings for my car.. but for my grand cherokee, each wheel bearing was $30, each seal was $8 and the each axle shaft was $150.
i ended up just doing seals, then selling it.. but stil.. you get the point.
Bearing 5.447R.........44.94
Bearing 5.484R.........58.24
Seal 5.469R.............10.12
Bearing 5.855R...x2...98.88
Bearing 5.536R...x2...98.16
Gasket 5.399R.........9.70
Cleaner 8.800..x2......5.34
Addt 8.800.............8.26
Lubricantion 8.800...x3...13.96
Spacer 5.453..........5.62
Sealant 8.800.........23.16
Seal 5.822R......x2...11.30
TOtal.....................446.20
I have no idea what the numbers mean but thats waht it says on my invoice exactly
Lubricant 8.800........13.96 - Axle Fluid
Bearing 5.447R.........44.94 - Front pinion bearing
Bearing 5.484R.........58.24 - rear pinion bearing
Seal 5.469R.............10.12 - pinion seal
Bearing 5.855R...x2...98.88 - carrier bearings
Bearing 5.536R...x2...98.16 - axle/wheel bearings
Gasket 5.399R.........9.70 - cover gasket
Cleaner 8.800..x2......5.34 - misc
Addt 8.800.............8.26 - misc
Lubricantion 8.800...x3...13.96 - limited slip additive
Spacer 5.453..........5.62 - crush sleeve
Sealant 8.800.........23.16 - not sure about this
Seal 5.822R......x2...11.30 - axle seals
$1100 isnt for just the axle bearings...I bet you had the pinion and/or carrier bearings making noise so they just rebuilt the entire rear end.
