Sponsored by: CARiD
Power steering question, with PICS
Old Feb 19, 2008 | 12:23 PM
FMX05's Avatar
Default Power steering question, with PICS
Ok, so hopefully the third times a charm.
I found a picture of an LS1 rack and basically I need to know if there is any sort of seal or O-ring in the fitting circled in red.
Dealerships in my area are no help and none of the online parts stores show any seal for this area. The "seal kits" are for the PS pump, and the orings are for the larger hoses, not the hard lines.
It is leaking profusely and I have tried some standard automotive O-rings per the suggestion of my local dealership's parts department(What a joke, it leaked just as bad or worse than before).
When I originally pulled it apart there was something that resembled a seal or O-ring in there but it was in such bad shape I couldn't tell what it was.
If there isn't supposed to be one there do you think I have a cracked line? And if there is a seal there does anyone know where I can get one?
Old Feb 19, 2008 | 01:18 PM
Greggy's Avatar
you can buy the whole hard line from the dealer for not too much. That will fix you up as it did me.
Old Feb 19, 2008 | 02:51 PM
FMX05's Avatar
Yeah that was the next step, I just didn't want to wait on a line to come in and still have a problem. I guess I can give it a try. Thanks.
Old Feb 19, 2008 | 06:58 PM
RE AND CHERYL's Avatar
It is a O ring but it's made of some sort of hard plastic. If you have one near you try a hydraulic parts supply house. I have a place near me that sells and makes hoses and gave me one when mine blew.
Re'
Old Feb 19, 2008 | 07:25 PM
FMX05's Avatar
cool, thanks. Finally a solid answer. We have a fastenal near here. I might try them.
Old Feb 20, 2008 | 08:46 AM
89Formulaws6's Avatar
when i took my lines off i didn't have a oring or anything and it didn't leak i just used teflon tape on it before i reinstalled the line, (my p/s fluid was toatsed) thats why i took the rack apart when i pulled my motor
Old Feb 20, 2008 | 11:05 AM
qwk93ta's Avatar
Is it very hard to replace the rack? Mine is leaking.......
Old Feb 20, 2008 | 11:29 AM
BIG_MIKE2005's Avatar
Neither did mine. Just flared ends & the nut tightened it down. Haven't had a single leak since installing a new set of hardlines.
Old Feb 20, 2008 | 02:19 PM
FMX05's Avatar
Thanks a lot people! I'm gonna run to the local pull a part and grab a line off a wrecked car. The dealership said it would be a week before I could get one in. If I try this and it doesn't work at least there is one on the way.
