Battery nut wont come off
Good day, I just bought a new battery and the positive cable wont come off. I used the right size wrench and now all the edges are rounded and the wrench spins. Can I get just a new nut or do I need a whole new cable for $75
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I actually ran into trouble finding one that was the same..they were all to long, so I just took a dremel cut off wheel and chopped off a couple millimeters. Works great.
yeah...maybe spray some pb blaster on it pull the rubber away its prolly all coroded...then use vise grips and see if you can break it loose then work it back n fourth, then you can slide the rubber away and pop the bolt out. You have to get the bolt out... GL
