Sponsored by: CARiD
Engine coolant leak plus white smoke.
Old Mar 2, 2008 | 12:01 AM
keys2myMARO's Avatar
Default Engine coolant leak plus white smoke.
So I was driving my car and then I get on the highway. All of a sudden I notice that I am leaving a big trail of white smoke behind and that the engine temperature is skyrocketing. I pull over, wait for it cool down and try to drive it again, same thing. So I get it towed to my place. I suspect that it was the engine coolant. So I pour a whole thing of coolant into my car and the car sucks it all up without any resistance. I notice that it was leaking the coolant out from the bottom.
Any ideas what broke?
I'm pretty sure it's the radiator.
Old Mar 2, 2008 | 12:20 AM
02 BLK WS6's Avatar
Water pump is toast or blew a hole in a radiator hose? Is it coming from under the front of the engine? Is it coming from directly under the radiator?
Old Mar 2, 2008 | 12:22 AM
I think its from underneath the front of the engine (its not a ls1, its a 3800).
I couldn't really see because it was dark.
Old Mar 2, 2008 | 04:06 AM
badazz99ta's Avatar
its most likely gonna be the waterpump. i just had to replace mine recently. it took me a minute to find out where it was coming from. well good luck man.
Old Mar 2, 2008 | 04:08 AM
ubnsmkd03's Avatar
id say water pump
Old Mar 2, 2008 | 09:10 AM
waiting2bl33d's Avatar
there should be a hole at the buttom of the water pump check to see if that is wet that.
Old Mar 2, 2008 | 03:15 PM
Well it may or may not be the water pump, but the hose that connects from the water hose to the engine blew off.
I gotta get that replaced, then see if there is something wrong with the water pump.
Old Mar 3, 2008 | 12:42 AM
waldershrek's Avatar
^^^Well that would be a big problem. Hopefully it was the only one.
