Sponsored by: CARiD
car problems
Old Mar 8, 2008 | 10:13 PM
myTreadZz's Avatar
Default car problems
Hey, my car is giving me trouble. Motor has 30 k so I'm pretty disappointed. I think the head gasket is going. Started the car yesterday and it poured white smoke like a sob. Low coolant light in dash was lit. Leaves a small puddle when started but after a minute no more leaking. I tried to smell the leaked fluid but I couldn't tell what it was. I turned the car off, then back on and the coolant light was off. Once warmed up took it for a drive, ripped on it 3 times, ran strong as ****. Brought it back home after 2 minute drive, temp was slightly lower and no more smoke whatsoever, even at idle. Stays about 8-10 degrees warmer when idling, but doesn't pass that point. Foamy **** is always in oil cap, don't think its condensation, but it hasn't been for any long rides so I can't say. Like I said I think head gasket but it has a shitty tune and cold weather causes it to run poorly when not warmed up so I have to get it checked out soon. Any opinions? Thanks
Old Mar 8, 2008 | 10:17 PM
SparkyJJO's Avatar
compression test
Old Mar 8, 2008 | 11:09 PM
myTreadZz's Avatar
Originally Posted by SparkyJJO
compression test
any mechanic should be able to handle that?
