Sponsored by: CARiD
Semi-Strange Blinker Issue
Old Mar 9, 2008 | 02:30 PM
Masochist's Avatar
Default Semi-Strange Blinker Issue
So, my left blinker works fine but my right does not work at all!
If I click it into place it just goes solid light on my dash and outside, could this be an issue with my passenger tail light which is also missing a light on the far right side when I hit the brakes?
Will new tail lights fix this issue? Could a wire perhaps be not plugged in properly? Any ideas are welcome.
Old Mar 9, 2008 | 02:40 PM
blackangel327's Avatar
you have a bulb burn out somewhere, turn it on and walk around which ever bulb isn't on thats the one you need to replace. I've got one on my car i need to replace but im to damn lazy
Old Mar 9, 2008 | 05:01 PM
kny3twalker's Avatar
replace your burnt out bulb and it will work again
Old Mar 9, 2008 | 08:25 PM
Jeresous's Avatar
same thing happened to me, believe I ended up replacing a side marker light and it worked again.
Old Mar 11, 2008 | 09:35 AM
VIP1's Avatar
Copy & Paste Moderator
Sticky:
https://ls1tech.com/forums/showpost....18&postcount=7
