Sponsored by: CARiD
AC Doesn't Blow Cold
Old Mar 15, 2008 | 06:34 PM
Crimsonnaire's Avatar
Default AC Doesn't Blow Cold
When the AC stops blowing cold air, does that mean it's low on frion? Is this what they mean when they say the AC needs to be "charged"?
Old Mar 15, 2008 | 07:46 PM
chavez885's Avatar
Yes. Hopefully thats the only reason its not blowing cold air.
Old Mar 15, 2008 | 11:52 PM
Daredevil_TA's Avatar
first off, your car will not take "freon" it takes R134a, an it could be possible that it needs a recharge but I would check your condenser first to see if it has a lot of crap stuck in it, if its full of bugs, twigs or anything of the sort that will affect the heat exchange an cause your A/C to feel warm.
Old Mar 16, 2008 | 01:38 AM
Cool!
I'll check the condenser before adding the R134a.
Thanks, guys.
Old Mar 16, 2008 | 03:04 PM
Vex's Avatar
Vex
Check and see if the belt is still down on the drive. It may have snapped and fallen off. Happened to me last summer.
Old Mar 16, 2008 | 06:30 PM
You mean the AC tensioner belt?
That's one thing I forgot to ask: If the belt is where it's supposed to be, is there any condition the belt could have that would stop the flow of cold air?
Old Mar 16, 2008 | 06:34 PM
redramair98's Avatar
does the compressor kick on at all?
Old Mar 16, 2008 | 10:52 PM
I'm afraid I don't know how to detect the compressor, but I can hear the usual 'on noise' when I go into AC. It's just that the air isn't as cold as it used to be. It has been quite a long time since I last used the AC though. Could constant use of the heater or constant alternation between the two cause a disruption?
I've been told that my AC tensioner belt is getting old, where it's capable of making a low chirping sound, but it's mostly silent.
Old Mar 17, 2008 | 01:46 PM
loyolacub68's Avatar
Go to Kragen or autozone and get a pressure gauge (they make them specifically for the A/C system). They are really cheap. Hook it up to the low pressure side of the A/C system (I can get you a picture of where it is if you need it). Then come back here and tell us what the reading is with the A/C off and the A/C on. You don't want to really start adding R134 if there is a leak introducing air into the system.
First, air in the system will cause premature breakdown of the A/C pump. Also, the A/C will not work as efficiently. It would be best to find the source of the leak and take care of that, so you don't have to constantly add R134 all the time (which is starting to get expensive).
Old Mar 17, 2008 | 06:32 PM
bigtim02ta's Avatar
just like they said if its leaking get it fixed because if it leaks down too many times and your trying to run it the compressor could burn out
