Sponsored by: CARiD
Oil Pressure Problem...
Old Mar 17, 2008 | 01:08 AM
BlueTA99's Avatar
Question Oil Pressure Problem...
hey was up! i have a 1999 Trans Am (Non-WS6) 6 speed manual transmission
everything is stock nothing is done to it but a regular K&N filter, other than that it is bone stock from the factory...
lately i been having an oil pressure problem...
at cold start the oil pressure is well over 40 ( im guessing 50 since its between 40 and 60)... n thats always at a cold start
now when im driving n warmed up, the oil pressure is at 40 (while im crusing)... but then after a little while, when im at a complete stop the oil pressure starts to drop little by little n the needle starts reading the oil pressure around 35... n then sometimes the needle starts bouncing from 35 to 39 back and forth (bouncing rapidly is that normal??)... when i start from 1st gear (regular driving) the oil pressure goes back up to 39-40... now lets say im doing 2500rpm on 3rd gear then i press the gas pedal half way i accelerate n it goes up to 4000rpm (still in 3rd gear), the oil pressure barely goes a little above 40...im guessing around 41-42 (i know its no more than 45)... and on top of that while reaching 4000rpm it starts to make a rattle noise (maybe my lifters or something from the valvetrain but i could/can be wrong)... the noise is pretty loud, i believe bcus of low oil pressure is wats making that noise (that its not getting enough lubrication) i could hear it from inside with windows up and down and is very annoying and personally it hurts me hearing that noise cus i feel that im screwing up my engine n now im afraid of going above 3000rpm...
but despite the noise n the oil pressure drop, the car is doing perfectly fine, i use my Trans Am as a daily driver to go to school and work n do erins, as long as i drive regular the car is good
my TA has around 60,000 miles, i dont know if the oil pump is acting up cus i hear that 1998-2000 models have bad oil pump, and i also hear that 1998-2000 that has over 50,000mile n having low oil pressure at warm temp. needs to change oil from 5w-30 (currently running) to 10w30 or is it my oil pressure switch???
so please i need help, opinions, advices, facts, suggestions or anything else please let me know...
i really appreciate you for taking your time reading this.
Old Mar 17, 2008 | 01:32 AM
Optimus_Prime's Avatar
Oil pressure increases with rpm, I believe the ls1 needs about 7lbs per 1000 rpm, i wouldnt worry about the pump until it starts to be around 30 or so at idle
Old Mar 17, 2008 | 02:52 AM
alacrity's Avatar
I have a 2000 ws6 and also have oil pressure problems. brand new oli pump and after warm up i drop between 25-35....but mechanic cant say why?
i dont ever hear any type of rattle though. maybe a spun rod bearing? i hope not for your sake.
good luck.
Old Mar 17, 2008 | 06:04 PM
FatZ28's Avatar
Actually the weight is the 2nd number. My pressure went from about 35 to 40 at idle when I switched form mobil 1 5w-30 to 0w-40 in my 98.
Old Mar 17, 2008 | 06:38 PM
F-BodyGuy98's Avatar
i had this problem with my 98 Z28..the car has a STS turbo system on it and when the car was cold the pressure was fine but after it warmed up it barley whent above 40...when i did my oil change i got rid of the Fram oil filter i was using and upgraded my oil from Castrol 5w-30 to 5w-40..i put a WIX filter on it and i added the Lucas oil stabilized the keep it from burning any oil...and it fixed the problem...recenty i used a K&N GOLD oil filter with the same oil and oil stabilizer...problem hasnt come back...if ur using a fram filter..get rid of that peice...when they get hot the bypass vavle in em doenst open all the way causin ur pressure to be low
Old Mar 19, 2008 | 09:55 AM
98FreakZ's Avatar
x2
Old Mar 20, 2008 | 11:35 PM
98LS1Formula's Avatar
use the long K&N and run 6 quarts , cant hurt
Old Mar 21, 2008 | 12:16 AM
Camaro396's Avatar
Mine used to be about 30psi idling and 40 under accelleration. Now I did my cam swap, and also did a New melling high volume pump, and royal purple 5w20 and she gets good oil psi
Cold @ 2500rpm:
Warm Idle is about 45-50psi
Old Mar 21, 2008 | 12:57 AM
kw's01z28's Avatar
Cold @ 2500rpm:
change your damn oil
Old Mar 21, 2008 | 09:20 AM
sworaz's Avatar
looks like it's about to explode lol
