Sponsored by: CARiD
oil & mpg
Old Mar 22, 2008 | 03:04 AM
Tommly's Avatar
Default oil & mpg
Hey guys,
I just changed my oil on an engine with 141k miles to mobil 1 extended mileage 5w30, and my mpg dropped at least 10%, what gives?
I'm pretty sure it was running conventional 5-30 before, but the manual called for either. This is a Nissan 3.0 V6, but it's making me wonder about what I put in my LS1 (redline 5w30).
I would really appreciate a little explanation.
Tom
Old Mar 22, 2008 | 11:50 AM
chavez885's Avatar
So...what kind of data did you create to make you think you lost "10%" mpg. That could easily be fluxuated by driving habits, tire pressure, outside temp.
Old Mar 22, 2008 | 12:19 PM
Tommly's Avatar
Good point...to be honest I wasn't that rigorous, but I make this 350mile drive about every other week on cruise control all the way. I gas up at the same station and arrive at the same location, and there was a significant drop in where my fuel needle ended up this time. The only factor I changed was the oil. Maybe I should sit on it?
LS2TA's Avatar
i would try changing the fuel filter and doing a fuel tune up might be the answer
LS1crazy01's Avatar
Yah 10% is nothing big. Thats probably just the driving conditions or somthing. I dont think its a good idea to switch to synthetic after running conventional for so long. Synthetic can cause things to leak when you switch like that. Just my opinion.
