SIdeways play in front wheels?
Any ideas? Now grab the wheel at the 12:00 and 6:00 position. If you get any play from there, it is the hub bearing starting to fail. All are very easy to fix in the driveway.
Now, use the channel locks and squeeze the ball joints. Keep constant pressure on them, and with a pry bar, pry between the ball joint and the lower a-arm. Keeping constant pressure with the channel locks will ensure that you don't mis-diagnose it. If you don't do that, sometimes you won't even feel any play. Be careful not to pry against the boot and tear it. Water and crap will get in there and cause pre-mature failure. If you feel any play there, then the ball joint either needs greased up, or replaced, depending on the amount of play that you find. If you need any more info or detail, just let me know..
