Sponsored by: CARiD
hesitation help
Old Mar 25, 2008 | 03:47 PM
2kSSCAMAROCONVERT's Avatar
Default hesitation help
wondering whats up with my car
if im driving on the highway going 60-65mph with no problems and then try to stomp on it the car seems like it hesitates for a second and then takes off til it gets up to about 75mph and then it bogs again for a second and same thing as it hits about 85-90 mph
should i try adding a gas additive? maybe have bad gas in the car or is maybe my cats starting to plug up?
only things done to the car are a new slp Y-pipe which throws a ses light (po420) code on a scanner ,and a new slp lid and a smooth bellows
any thought would be great
Old Mar 26, 2008 | 04:22 PM
CJDZ24_Z28's Avatar
Check the MAF sensor. Check and see if its dirty. Clean it with some MAF sensor cleaner available at your local parts store.
Old Mar 26, 2008 | 06:54 PM
ae13291's Avatar
could be fauled plugs! i had a cracked spark plug, that was my hesitation under load problem!
Old Mar 26, 2008 | 08:46 PM
Nickstock98t/a's Avatar
I had almost similar prob. I just added stuff to my gas tank. Still did it. I ignored it and wala it gone. I noticed this started happening when I was really ***** footing and using San diegos poor quality gas . I think these cars just really wanna be driven. I say add some techron Or sea foam to your tank. And if its still DOIng it, just ignore it. I'd start worrying when it starts being really consistent and worse.
Old Mar 26, 2008 | 09:23 PM
dbrown's Avatar
I had the same problem on a 99 Full Size... Replaced the fuel filter and plugs. Fixed the problem.
Old Mar 27, 2008 | 12:16 AM
sevenstarsfall's Avatar
Whens the last time youve done a tune up ie: plugs, fuel filter, air filter, pcv valve, etc?? If its been a while Id start there.....
Old Mar 27, 2008 | 03:16 AM
thanks for the input
gonna give her a tune up and see if that works--she's do for one
