P-0440/0442 - Possible Causes?
It was suggested to me that a bad gas cap could cause these codes, but aside from the cap, what else could cause them to go on? The light disappears for a while every now and then.
I was told that it could cost $500-800 just to have this professionally taken care of!
Is there a shop I can take it to that costs less than Meineke to do this? How much did that shop charge your friend?
SOP for evap system is to check it over visually (looking for cracked hoses) and if nothing is obvious, use the smoke machine. I have never charged anyone more than an hour's diag time ($80-$100) to find a leak.
MOST of the time when you do find the leak, it's a rubber hose that can be replaced that doesn't cost too much...
I think if I couldn't fix it myself I might *gulp* go to the dealer...at least they'll be more familiar with your EVAP system and won't be chasing their tails on it like a meineke might.
Meineke charges $100 for the initial electronic diagnostic, plus the cost of the part and labor will add up good. The guy told me straightforwardly that the cheapest he's charged for this kind of thing was around $500. I want to get rid of because if something else goes wrong, the codes will get mixed with the present ones, and I won't know anything because the light would already be on.
The twist cap in front of the arrow is missing on mine. I've always wondered what that's for, or if it's supposed to be covered.
If you know someone with a scan tool, have them clear the code after you make sure the cap is tight. Then see if it comes back on before you pay some "professional" to diagnose/guess what the problem is.
This was many days since I filled gas, plus I already replaced the gas cap with a brand new one a while ago. Incidently, I noticed that the plastic ring that sits around the gas tank hole (below where cap sits on) was twisted up with the wire pulled up a bit. I turned it back and let the excess wire length go down into the little wire hole. It was after this that the light went away for about a good week.
Could a ruptured intake manifold set off these codes...?
