TPS and IAC sensor plug/pigtail question
Anyone parting out a car that wants to send me one? I need it by the end of the week.
Thanks!
TPS connector as a "3 Way Female Metri-Pack 150" - GM/Delphi part number 12110192
IAC connector as a "4 Way F Metri-Pack 150.2" - GM/Delphi part number 12162190
This catalog should have a picture of the IAC connector on the last page for you to confirm: http://connectors2.delphi.com/dcsgdm...ion/met150.pdf
You can check the TPS and other connector specs at this site: http://connectors2.delphi.com/DCSGDMCS/HomePage.aspx Just enter the part number and it will give you drawings, related parts, etc.
FYI - The numbers above are just for the connector housings. The terminals, terminal locks that click to the back of the housing, etc. are all separate part numbers.
A dealer may be able to get these parts for you. The part numbers match to GM numbers, but often times these get discontinued or listed under new part numbers. You can also search for "Metri-Pack 150" online and find people who deal in them.
If you have problems, let me know. I know of places who can get you new parts, but probably not before the coming weekend.
