Sponsored by: CARiD
Harmonic from transmission tunnel. HELP!!!
Old Apr 5, 2008 | 07:26 PM
DOUBT IT's Avatar
Default Harmonic from transmission tunnel. HELP!!!
Alright, here's the situation:
Swapped from a Jegster non-adjustable TA to a stocker with the UMI TA relocation crossmember yesterday to cut down on gear whine/resolve some vibration/clunking issues I've been having.
New crossmember works great, gear whine is back to being quiet enough to hold a conversation in the car, medium vibration at 70 is gone, clunking when on rough roads or hitting bumps is gone, and the car FEELS more solid. I should be happy right? Nope, got a new problem.
Heard a HORRIBLE new vibration/whine/God-I-don't-know-how-to-describe-it noise. Took a friend out on the road to get some help with figuring out where it's coming from. Figured out that it's coming from the transmission tunnel itself! If you feel the side of the tunnel next to the driver's seat, there is a hellacious vibration while the noise is occuring, it's like the tunnel is resonating with something in the car.
Talking with my friend, the only idea that we can come up with is that the fuel/brake lines that I flipped to fit my true duals higher are vibrating at JUST the right frequency. They are resting against the torque arm mount on the crossmember at the moment, I plan to take some rubber hose tomorrow and isolate the hoses from each other and the crossmember, hopefully that will take care of it. It's driving me nuts! If I can't get it figured out tomorrow, I'll take a video of the noise and post it for you guys.
Anyone seen anything like this? Any ideas besides the one that I already have? ANY help would be appreciated guys, this is my only car right now.
Old Apr 6, 2008 | 03:44 PM
DOUBT IT's Avatar
Figured it out. One of the brake lines had come loose from the clips, and was sitting snug (not tight) against the body and vibrating at exactly the wrong moment. Fit it back up into the clip, and put rubber around it so that if it popped out again, it wouldn't rub and cause the vibration again. Also put rubber around the front of the TA mount where the lines were up against it. The noise/vibration/buzzing is 90% gone, and I just put the console back in, that should take care of the rest.
Just in case, I'm getting some sound-deadening material sometime soon and re-lining the transmission tunnel inside. I took off the trans sound deadening a long time ago thinking that I would never need it... I was wrong!
Bracket Pics:
Brake line up against body:
Lines up front, and torque arm mount:
Looking down the driveshaft, over the duals at the crossmember:
