oil coming from dip stick
There are a lot of things that can cause this.
I had an old big block that would blow the dipstick at high rpm, found out one of the filtered aftermarket valve cover breathers just didn't have a big enough opening to handle normal ventilation. I installed a better flowing breather and fixed the problem.
A good start would be a leak down test to see how well the rings are seating and see if the crankcase is ventilated well enough and nothing is blocked.
Did it blow the dipstick out the first time you got on it after installing the supercharger? If it did then you may have a PCV issue. If this problem just recently arised then something probably happened inside the engine to cause the change. In my case #7 had 90% leakdown.
No one said it? I said it 16 days ago.
