Power window motor issues
Last edited by camaro_five0; Apr 10, 2008 at 11:19 AM. Reason: Forgot to mention "driver's side"
I had problems with the regulator rollers in the tracks binding, that was causing mine to skip, hang and burn up motors...
https://ls1tech.com/forums/general-maintenance-repairs/896968-new-window-motor-spot-q.html
Good luck!
BT
If that coil was somehow broken or not working the window would never go back "up"...
Have you seen the kind of tension that is on that coil???
The weight of the glass alone ( after in the down position ) would be too much for just the motor to even move at all...
BT
How do you think it is able to pull the window down so fast?
Um, weight of the glass.
When I disassembled mine and didn't get the spring back in correctly with enough tension it would only go down and not up. That was with a new motor also...
I don't know what to tell you.
That was from my own personal experience...
They must be pretty weak if they have a hard time getting the window back up with the spring installed correctly with minimum binding in the tracks from the rollers sliding and not turning.
So I'd say it's pretty weak yes...
Installing auto glass has nothing to do with the operating mechanics of regulators and motors...
Cheers!
