noise when turning steering wheel!!
Otherwise, power steering noise tends to be either rack or pump related. In either case it's expensive and a PITA. In the meantime, you can try flushing your power steering with a turkey baster, try a search.
a clicking sound while in motion would probably be your hub (bearings). this clicking would change pace with your speed and possibly only sound while turning in a specific direction.
a popping noise while turning your wheel moving or not is likely your rack and pinion.
the whine is kinda normal just your power steering working a little harder than it should have to.
first change the fluid regardlees it's easy and inexpensive.
the hub or rack each would set you back around 135 but the hub is extremely easy and the rack is difficult and will require an alignment
give more detail
