Sponsored by: CARiD
Passenger Side Mirror Doesnt move up
Old Apr 13, 2008 | 11:59 AM
tomf301's Avatar
Default Passenger Side Mirror Doesnt move up
Drivers mirror moves in all four directions but passenger only moves in, out, and down. ????????
Old Apr 13, 2008 | 09:43 PM
98LS-WON's Avatar
Try slapping your mirror/slamming your door a few times. Good luck if that doesn't work. Start checking the connections then, the switch itself.
Old Apr 14, 2008 | 05:32 AM
Shooter_Jay's Avatar
Could be an electrical problem, so don't rule it out on my account, but the mirrors snap into place. which means they can snap out. I've dislocated my driver mirror while washing it before, and I could see it vibrating a bit and the adjustment didn't work well. If it's loose, pull it off and look at how it snaps in. Then snap it in. I'm talking about just the flat mirror part that adjusts, not the whole painted housing.
Old Apr 14, 2008 | 07:47 AM
wssix99's Avatar
Save the manuals!
The mechanism may be disengaged. Try pressing down on the mirror while operating the button and see if it catches again.
Old Apr 14, 2008 | 09:13 AM
Camarojunkie's Avatar
It actually takes a good amount of pressure to snap the adjuster arm into the mirror backing plate so just be carefull not to brake the mirror make sure you have the pressure directly on top of the point where the two snap together. Always look at the mechanism first to make sure the plastic adjusting arm itself is not broken which sometimes happens for no reason.
