Sponsored by: CARiD
Interior Trim
Old Apr 17, 2008 | 09:15 AM
brapril714's Avatar
Default Interior Trim
I believe it's the B-Pillar(panels by rear seat), the driverside keeps coming loose at the door. Is there a way to fix this?
Old Apr 17, 2008 | 11:16 AM
SLOW30th-TA's Avatar
yeah, mine too, I just keep pushing it back in
Old Apr 17, 2008 | 03:40 PM
patriot1136's Avatar
can you get new plastic tabs? i think thats what holds them in there right
Old Apr 17, 2008 | 04:06 PM
brapril714's Avatar
I'm going to take it apart tonight and check everything out. I believe gm recommended placing a screw behind the speaker grill cover.
Old Apr 18, 2008 | 11:41 AM
wssix99's Avatar
Save the manuals!
Yes - GM released a TSB on this problem and will fix it if its still under warranty. The solution was use a self-tapping screw to secure the plastic behind the speaker grille.
If interested, let me know and I think I should be able to provide the TSB and install instructions. (Don't have them with me now.)
Old Apr 18, 2008 | 11:45 AM
brapril714's Avatar
Please post them, does it say what size screw
Old Apr 18, 2008 | 03:59 PM
^^^^^^^ Me as well. Please post.
Old Apr 19, 2008 | 11:27 AM
Viper's Avatar
I imagine a 7mm screw would be small enough to hold that plastic tab down...
Old Apr 19, 2008 | 12:41 PM
wssix99's Avatar
Save the manuals!
Here's the TSB details:
Bulletin #: 0008110004
Sequence #: 616357
Date: 10/01/2000
Component Name: 162000 structure:body
Summary: Some vehicles may exhibit rear quarter trim gaps to the b-pillar.
I threw out my instructions way back when, but (if I recall correctly) they come with the two needed screws in a "repair" kit, which you can still get from GM for around $5 - part # 11519838. If you don't want to spring the $5, they are #8, 1/2 inch long pan head sheet metal screws. The ones that come from GM have alternating threads - one thick and one thin.
The problem seems to be caused when the panels age and shrink a bit. (See the door crack issue also.) When this happens, the Velcro pad under the speaker hole can't keep the panel in place.
The repair screw goes through a speaker grille fastening point, just above this velcro pad.
Since the plastic piece involved is thin and fragile, I highly recommend drilling a hole vs. using a self-tapping screw. You should also make sure the panel has engaged the velcro and is in the right place before you drill. If you are off by a small bit, the panel will be off.
Attached Thumbnails Interior Trim-8-one-half-inch-self-tap-screw.jpg   Interior Trim-speaker-wide.jpg   Interior Trim-speaker-close.jpg   Interior Trim-velcro.jpg
Old Jan 6, 2023 | 08:16 AM
cancam99ss's Avatar
following
Old Jan 6, 2023 | 11:45 AM
bleepster's Avatar
following a 15-year-old thread?
