Sponsored by: CARiD
Car is running lean, 3 codes
Old Apr 26, 2008 | 05:11 AM
TripleWhite96's Avatar
Default Car is running lean, 3 codes
I'm popping 3 codes, running lean in bank 1 and 2 and idle rpm high, car seems to struggle to idle right and sometimes leaving a stop it about stalls than bam instant power with no issues..anyone know what could be causing this issue? I have to change my battery real soon as I'm getting the infamous needle movement and trip meter reset at startup but that I dont think is the issue. Thanks for any advice!
Old Apr 26, 2008 | 09:17 AM
yeller_xtc's Avatar
i had the lean bank 1 and 2 codes on my car turns out it was a crack in the hose from the pvc valve...after i replaced that it went away. and hasnt been on since..i would check that first...make sure your pvc still rattles when you shake it too..
Old Apr 26, 2008 | 10:14 AM
Formula413's Avatar
That all definitely sounds like a vacuum leak. Take a can of carb cleaner and spray it around all the vacuum lines going into the intake manifold, PCV, brake booster, fuel pressure regulator, anywhere there is vacuum. Listen for a change in the idle. Any air entering the engine after the MAF sensor will cause a lean condition.
Old Apr 26, 2008 | 12:28 PM
going to check on that right now, hope thats all it is
Old Apr 26, 2008 | 02:17 PM
sure enough, thats what it was. PCV vacuum line had a hole and was worn to gooey garbage
Old Apr 26, 2008 | 02:48 PM
yeller_xtc's Avatar
glad to help! it will take a few days for the code to clear i think. i used fuel line to replace that hose...
Old Apr 26, 2008 | 03:25 PM
Formula413's Avatar
Sweet!
