Sponsored by: CARiD
Pulling and swaping ls1 engine in an fbody
Old Apr 27, 2008 | 10:17 PM
bigfatls6's Avatar
Default Pulling and swaping ls1 engine in an fbody
Is there a way to lift the front of the car up off of the kmember using a chain hoist? I don't have a car lift but I do have a large chain hoist that would lift the front of the car high enough. where should I hook the hoist to to lift the front of the car with out damageing any thing?
Old Apr 27, 2008 | 10:44 PM
Mike2kZ's Avatar
i would think the front bumper support since it ties into both sides of the sub frame. That's what I'm planning on lifting from with my hoist when I put the new motor in.
Old Apr 27, 2008 | 10:47 PM
tylerdj's Avatar
Yes, I've seen it done many times by a cherry picker. When I did it I just pulled the engine/tranny out through the front though.
bigfatls6's Avatar
If you find a post about this that gives the locatio to lift from let me know. I tried to search and all I found was how to remove the engine on a lift from the bottom.
Old Apr 27, 2008 | 10:51 PM
bigfatls6's Avatar
so you pulled it out the top? how did you pull it from the top? I am guessing you removed the manifolds or headers, intake and heads? How did you attach to the engine to pull it out? I have a cherry picker and a large chain hoist thats set up on large steel I beams.
Old Apr 28, 2008 | 08:37 AM
tylerdj's Avatar
Pulling the motor/tranny from the top requires you to unbolt the headers, and remove all of the accesories off the front of the motor. Then I used a plate that bolts where the valley cover goes and pulled them right out.
Here's some pictures of how we did it on my brother's old camaro. I did it the same way on my TA though.
http://www.cardomain.com/ride/716929/2
Old Apr 28, 2008 | 03:20 PM
bigfatls6's Avatar
Does some one sell the plate that you used? does any one have any info on using a hoist or cherry picker to lift the front of the car off of the engine and k member?
Old Apr 29, 2008 | 05:17 PM
Mike2kZ's Avatar
I pulled mine from the top. I don't know what I was thinking. Pull it out the bottom, front suspension, pcm and all.
Old Apr 30, 2008 | 06:11 PM
staringback05's Avatar
yes, is there a special reason why your wanting to take it out the top?...its tons easier to take it out the bottom...
tyler...we all know why you took it out of the top...
Old May 1, 2008 | 02:18 AM
bigfatls6's Avatar
I would definetly rather take it out the bottom but I don't have a lift. I do have a cherry picker and a large chain hoist mounted about 10 feet above the ground. I have been trying to see whats the best way to hook up to the front of the car to lift it.
Old May 13, 2008 | 09:03 AM
tylerdj's Avatar
We made a plate similar to this that attached to the valley cover http://www.automedia.com/Camaro_Cher...ht20020701ch/1
You have to take off all the accesories down to the block to get it out though.
