Sponsored by: CARiD
Rear Hatch
Old Apr 30, 2008 | 10:24 AM
Mikzgp's Avatar
Default Rear Hatch
I have this problem with my 2000 WS6. I didn't know if eveyone else had it as well or not., but I have to push the trunk button 2 or 3 times before I can open the trunk. I saw this on e-bay but was wanting to know if anyone has tried this or found a better fix.
http://cgi.ebay.com/ebaymotors/Rear-...QQcmdZViewItem
Old Apr 30, 2008 | 10:55 AM
DevilDougWS6's Avatar
take the carpet away from the rear latch, and put a smaller tighter spring piggybacked on the spring there, that will pop the trunk up in one shot.
**** that 10 dollar piece of ****, all it is, is a tighter spring. you can get one for like a dollar or even free if you look. that thing on ebay is a waste of money. just go to a hardware store and find a shorter spring similar to the one on the latch. mine pops sky high now (not really but it opens on the first shot)
edit: you are talking about the INSIDE trunk release correct? cause the remote you have to press twice anyway. that fix is when you press the release and it wont pop up and you have to pull up on the hatch and press the release.
Old Apr 30, 2008 | 01:08 PM
Mikzgp's Avatar
Yes that is what I am talking about and I found an old tread on it, but in there some people were saying it only worked for about 2 - 3 months and it was back to the same way again. I didnt know if that might be a better spring or something. I guess I will just try and piggy back it with a new one. Thanks
Old Apr 30, 2008 | 01:11 PM
98boxer's Avatar
i always have to press my door hatch button 3 times and my hatch doesn't pop up, don't think it every did since i got her used
Old Apr 30, 2008 | 01:16 PM
Mikzgp's Avatar
I got mine used last year as well and I tryied spraying it with WD40 with no luck. I was looking on e-bay when I found that. I will try to do it my self like DevilDougWS6 said.
Old Apr 30, 2008 | 06:03 PM
ls1silverta's Avatar
Same problem here...didn't realize it was so common.
Old Apr 30, 2008 | 06:07 PM
Tally TransAm's Avatar
you can also lower the little stoppers on the hatch to give them some more preload and see if that works
Old May 1, 2008 | 09:36 AM
Luder[PAK9]'s Avatar
installuniversity.com has a write-up on the spring fix. I did it. Spring is $3 and took about 5 min to do.
Old May 1, 2008 | 10:12 AM
LastHawk's Avatar
I had the same problem. I used the installuniversity.com write-up and piggy-backed another spring. It has worked flawlessly for the past 2+ years. Definetly give it a shot before you do anything else. I think the spring was like 39 cents at home depot.
Old May 1, 2008 | 03:47 PM
Schnell's Avatar
That ebay post doesn't say what the part is... I'm willing to bet all you get is a spring in the mail.
Old May 1, 2008 | 05:14 PM
davered00ss's Avatar
Moderator
www.installuniversity.com
LSX vehicles
Install documents
Old May 1, 2008 | 05:16 PM
Moderator
The link does not even show the parts. it's probably just the piggyback spring.
Old May 1, 2008 | 11:31 PM
2000Hawk's Avatar
I tried the piggyback spring and it didn't change at all. I said f*ck it, took the spring off and just keep pushing the button a bunch of times to open. I figured it would open with no problem, but that thing just opened the same with the piggy back spring on it.
-Joel
Old May 17, 2008 | 03:21 PM
xRelapse13's Avatar
just do the install univ one, it worked great for me
