Old 04-29-2016, 05:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Interior Guides
Print Wikipost
dash vents not blowing air??
Old 03-29-2010, 03:49 PM
mike171562's Avatar
I believe its GM Part# 14056648, i got 5 in a bag at Advanced Auto today for 1.98
Old 03-29-2010, 10:26 PM
SlayerMaro's Avatar
Did you guys experience other issues associated with vac leaks while you had this one?
My top A/C vents don't work, and I also have the idle issues associated with a vac leak. Just wondering if that could be the cause.
Old 03-29-2010, 11:33 PM
cnw8891's Avatar
Thanks. But after having 3 or 4 more of the GM check valves split, I rigged my own with a regular check valve and a t-fitting. I've had no problems since.
I had no other vacuum issues.
Old 04-01-2010, 08:52 PM
Elthesh's Avatar
For what it's worth... My 10 year old check valve just died and i replaced it with the Dorman version of that part. Works great now. Too bad I missed it on the first check and bought a new switch for inside. Man, that switch is a major pain to replace. but at least its shiny new now. The check valve was split along the line where it molds together along with a huge split lengthwise. Easy quick repair though.
Old 04-04-2010, 08:13 PM
Dan
Dan's Avatar
Mine did this a few years ago when I put on the LS6 intake(98 T/A)..The hose on the back came off & I tackled it today after 6 years..Well I had to pull the intake to hook it back up. No dice, still no air thru the vents. I tried both T splitters,(one from my 99 T/A) So I don't know what the hell is going on. I know the T Splitter on my 99 is working but honestly not all the time. I would put the air on & for a minute it would stop blowing out the vents & then start again. maybe I just need to start fresh with 2 new T splitters & see what happens. I busted my ***** taking off that intake today thinking this would fix it
Old 06-18-2010, 07:57 PM
bluebird71's Avatar
I found the little black hard vacuum line behind the manifold and it's off on mine too. Problem is, I can't get it back on there for the life of me. It feels like it's the same size as the nipple it plugs into. I no longer have any EGR stuff and I had a FAST intake on it before the turbo build. Do I need some kind of connector that steps the nipple down or something?
Old 06-18-2010, 08:12 PM
fleetmgr's Avatar
can you make a splice from a piece of vacuum hose?
Old 06-18-2010, 10:12 PM
bluebird71's Avatar
Ok, nevermind, I got it connected and it worked. The AC and upper vents now work. I also had to replace the compresser fuse as well.
Old 03-21-2012, 05:06 PM
desormeaux05's Avatar
Where exactly does the vacuum line go on the back of the intake manifold? I just can't seem to find a nipple there for the life of me.
Old 03-22-2012, 03:13 PM
KrisXpc's Avatar
Where can i find the vacuum line connection for the vents? Is it on the Hvac box? I know where the connection is on the intake, just not for the vents. Had the engine removed and engine bay painted i doubt that the painter ever hooked it back up.
Old 03-22-2012, 03:58 PM
mike171562's Avatar
The following users liked this post:
Gold TA (06-11-2022)
Old 03-22-2012, 05:04 PM
  #32
KrisXpc's Avatar
I want a pretty picture with labels answering my question too =[
Old 03-22-2012, 08:33 PM
  #33
djfury05's Avatar
There should be a vacuum line coming out of the HVAC box to the left of the heater hoses at the top. This is the line that all the other vacuum lines connect to with the T fitting. One line of the T fitting goes to the back of the intake as shown above. The other line runs down the passenger side and into a vacuum canister under the frame fail near where the horns are. Are you saying you don't have the line coming out of the firewall anymore?
Old 03-23-2012, 08:15 PM
  #34
KrisXpc's Avatar
You Rock man.. I had the nipple at the firewall but no actual lines.. First time in 4 years the vents have actually worked.. Since i only have heat in the car and i dont drive it often it's not been a huge worry..
Old 04-10-2012, 12:58 AM
  #35
sxemama's Avatar
I'm having the same problems. Just comes out the defrost vent. I know nothing about where these things are located, so how exactly do i access whatever i need to check?
Old 04-12-2015, 04:56 PM
  #36
stroked383HSR's Avatar
ok...im bring this back from the dead...well atleast 3 years dead
my dash vents are not working for some reason. I did a search and came up with this thread.
I switched from an LS6 to a fast 92 intake and know for sure I connected everything that was back there.
on the fast 92 I didnt have a connection for some extra hose for my top dash vents
all i had was for the brake booster
so whats up?
i do know that when i had the lS6.....everything worked perfect....dash vents and all
Old 08-04-2015, 09:47 AM
  #37
boostwhipped24's Avatar
Did you find your answer. Im having some problems on mine also, heat from feet and defrost only. So I was checking the valve by the pcm and feeling around the back of the intake, when i found this.
Is this my problem.
Old 05-15-2016, 07:46 PM
  #38
FCar2000TA's Avatar
I had the same problem after pulling my LSX intake. I couldn't figure out where it was, so I searched...here is a post about this connector on the FAST intake
https://ls1tech.com/forums/generatio...ake-issue.html
Old 07-04-2016, 02:54 PM
  #39
CruzinTA's Avatar
Holy crap i'm glad i found this post. Almost starting buying HVAC sh*t off rock auto. I specifically remember yanking something off the back of the intake when removing AIR/EGR this winter. Had to exact same problems. Can't wait to check this when i get back from vaca!
Old 09-05-2016, 10:46 AM
  #40
Michael Restaino's Avatar
Default Ac vents issue
So i been reading everybody's posts and in order for me to resolve my issue i have to pull off the intake or is there another way please advise all information is helpful thank you
Quick Reply: dash vents not blowing air??
