Sponsored by: CARiD
Windshield wiper arm removal
Old Jun 7, 2008 | 08:36 PM
nls8520's Avatar
Default Windshield wiper arm removal
What is needed to remove the windshield wiper arm on a 2002 trans am, I need to replace both of my wiper arms, and need to know how to do this, thanks in advance.
Old Jun 7, 2008 | 08:42 PM
yeller_xtc's Avatar
i think a 10mm and alot of willpower! lol! it took a small gear puller to remove mine..maybe you wont have as much trouble as me..
Old Jun 7, 2008 | 08:47 PM
2002_Z28_Six_Speed's Avatar
I tweaked a 3 jaw puller and made it work. I am pretty sure the dealership has a tool for it though.
Old Jun 7, 2008 | 09:02 PM
zanethan's Avatar
I used a gear puller as well. Be careful around the windshield its easy to crack.
Old Jun 7, 2008 | 09:28 PM
nls8520's Avatar
Can I take the arm off without removing that plastic shroud that houses the wiper arms?
Old Jun 7, 2008 | 09:34 PM
zanethan's Avatar
If youre talking about the plastic that goes around the windshield then yes they can be removed without removing it.
Old Jun 7, 2008 | 10:45 PM
nls8520's Avatar
Why do I need a gear puller?, is it that hard to get off?
Old Jun 8, 2008 | 12:54 AM
The splines are tapered but they are subject to weathering and may be rusted together slightly.
Old Jun 8, 2008 | 09:45 PM
nls8520's Avatar
So me best bet is a small gear puller then to get theses wiper arms off. Other cars I have owned, You just pull the wiper arm up and twist the **** at the base off and the wiper arm will come right off.
Old Jun 8, 2008 | 09:50 PM
Try to get it off normally at first. If that doesn't work then try the gear puller.
