Sponsored by: CARiD
How do you remove Coolant sensor
Old Jun 9, 2008 | 11:18 AM
peterlawl84's Avatar
Default How do you remove Coolant sensor
It seems that my engine coolant sensor is bad since the light keeps coming on, but the radiator is full. I did a search and all I came up with is to unplug it, but my question is how do you remove the sensor? I think I have found it and can unplug it, just not sure which way to turn it to remove it?
Thanks
Old Jun 9, 2008 | 11:57 AM
2001NBMZ28's Avatar
My car doesn't have one, but maybe similar to the LT1?
http://shbox.com/1/low_coolant2.jpg
Old Jun 9, 2008 | 12:08 PM
2002_Z28_Six_Speed's Avatar
LT1 Only.
Old Jun 9, 2008 | 01:28 PM
Originally Posted by 2002_Z28_Six_Speed
LT1 Only.
Sorry are you talking about the previous post or that only LT1s have this sensor? I have a 99 t/a
Old Jun 9, 2008 | 02:19 PM
2001NBMZ28's Avatar
The 98 and 99 cars have the sensor. Posted the link in case yours looked the same.
Old Jun 9, 2008 | 04:56 PM
I was talking about the previous post. Sorry.
REALLY? I have seen a 99 without it. I would more than bet that car was modded/it was removed.
Now, I know!
Old Jun 10, 2008 | 07:28 AM
wssix99's Avatar
Save the manuals!
Does the light go out after the car comes up to temperature and the thermostat opens up? (I'm having the same issue, but my light goes out after the coolant starts flowing through the system.) I just replaced my radiator cap to see if its letting air in the system. The old one was really bad - we'll see if it worked today.
Old Jun 10, 2008 | 09:04 AM
My light comes on randomly when I am driving. The temp gauge is right under 210 the entire time and the coolant levels in both the radiator and reservoir are full. Oh I have the SLP high-flow radiator and the 160 degree thermostat if that makes a difference (but those have been in for several years and this problem just started earlier this year).
 Michael S. Palmer
Old Jun 10, 2008 | 12:13 PM
Shake's Avatar
My sensor is acting up (full time) as well. I would be very interested to hear what it takes to clean, repair, or replace it.
Has anyone ever successfully done this, or has everyone just unplugged the harness and forgotten about it?
Old Jun 10, 2008 | 11:35 PM
Johawk's Avatar
I had the same problem with my 99 Formula and eventually the light didnt go off anymore when the engine warmed up and was on all the time. A metal C clip holds the sensor into the radiator. Remove the clip and the sensor pulls right out. Dont lose the O-ring on the sensor. Its very simple to replace. It should be on the passenger side radiator end tank just below the cap
Old Jun 11, 2008 | 09:37 AM
Thanks for the info...I am assuming I need to drain the radiator some also to prevent it from leaking out??
Old Jun 11, 2008 | 12:23 PM
02gtp4now's Avatar
i did this on my 96 just make sure the cars cold some might come out but no need to drain
Old Jul 11, 2008 | 03:38 PM
slow3hoe2's Avatar
good info. im having the same issue on my 99TA. i started the car one day and the radiator light was on. looked to see the level and it was fine. drive for a bit and it would go off. now if never goes off unless i turn the key off and on once warmed up. anyone replace the sensor yet? just wondering how much it was.
Old Jul 12, 2008 | 09:17 AM
wssix99's Avatar
Save the manuals!
I was having the exact same problem <above> and just replaced the sensor. It took care of the problem like a charm. I got my sensor from gmpartsdirect for $34. They seem to be the least expensive place for this kind of thing, but they take forever. I had to wait over two weeks to get the part.
