Sponsored by: CARiD
Need help with starter
Old Aug 14, 2003 | 02:27 PM
ALPINE's Avatar
Default Need help w/starter
My starter went out yesterday, and I am having trouble finding a "how to" on changing it. Anyone have one? Along with changing that, I'm upgrading my ignition to some MSD I think, and need some advice on ignition which to use. Thanks,..
Old Aug 14, 2003 | 08:25 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Need help w/starter
There are only two bolts holding the starter on. Then there is a plastic dust cover under it that keeps stuff from getting into your bellhousing. Pretty easy to swap out.
Tony
Old Aug 15, 2003 | 09:25 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Be careful with the wires. It's easy to swap, the bolts are 15mm...
You should disconnect your battery first.
If you have your radio locked with the theft thing you need ot unlock it unless you have the code for it.
