Gas mileage decreasing?
I haven't noticed any uneven tire wear or abnormal handling/riding so I think I should be ok there.
Thanks again for all the input!
I would also make sure you clean your MAF because you are oiling your air filter way too much! If your MAF gets fouled with oil, the PCM will sense less air going in to the engine and will change your fuel mixture accordingly. (GM says these filters foul the MAFs - the filter manufacturers say the MAFs are defective and leak silicone. From what I've seen on my car, there may be some truth to both claims - depending on the situation.)
Check your manufacturer's instructions on the air filter. If I recall correctly, they work better when they get "dirty" and clump dirt on to the oil. All that is needed for normal cleaning is to shake the clumps off. (I believe my old K&N recommended re-oilings at intervals over 50,000 miles.) If your filter is "clean" and wet with oil that often, you could be sheading enough on your MAF to cause a problem.
I do make it a habit to clean my MAF often though just for that reason. Also, you are right the filter is supposed to only be re-oiled once every 30k miles or so but still Im kind of **** when it comes to dirty filters lol. I kinda regret the free ram air mod now haha.
