Radiator cap blew off
So I tried a search and didnt find exactly what I was looking for.
I was sitting at a light and I noticed a little bit of smoke coming from the passenger side of my hood and I started to smell coolant, just like the time i blew my head gasket
I figured that couldnt be the problem because I havent been ******* the car or beating on it or any such thing. I babied it home the next 3 blocks and when I got home and popped the hood I noticed that the radiator cap had blown off
It had spit out a bit of coolant but I've been told that radiator caps can go bad and the same thing happened to my brothers old caddy. It has no other known issues and 60k miles on the motor.
Any other thoughts or ideas?
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Oh well, **** happens
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
your belt system is probably saturated with coolant (slipping) on top of that you may now have air in the cooling system that needs to be bled out. I wouldn't assume it's the water pump yet.
instead of writing up a new thread ill just post in here:
could air in the cooling system cause a water pump to squeal? or any kind of squealing noise for that matter? I let the car run and filled the radiator up til the level stayed steady with the t-stat open and havent had any issues since then, but i do notice a slight squeal. its not nearly as loud as it was when i first had these problems.
