Sponsored by: CARiD
slp manual fan switch install?
Old Jul 29, 2008 | 08:43 PM
rxrom's Avatar
Default slp manual fan switch install?
I bought the manual fan switch from slp. Searched old post. They all say easy 15min install. I'm not the most tallented tinkerer but tried to intall it and ran into a hurdle. Where do I run the wires from the engene compartment into the interior. Old post say passenger side gorment?? Can't find anyplace to run the wire.
thanks
Roman
Old Jul 29, 2008 | 08:51 PM
Blazingz28's Avatar
Take out 2 bolts holding computer , passenger side on the corner, flat box.
Pull it out. clean out the 1000 leaves, then you can run it with those wires, and it goes under the dash i believe.
Old Jul 29, 2008 | 08:54 PM
DrkPhx's Avatar
There is a rubber grommet located on the passenger side firewall under the PCM. It's where the wires from the PCM are routed directly into the interior. You need to remove the front interior kick panel to access it. Once located you will have to pierce a small hole into the grommet and route the fan switch wire through it.
Joshiedoom's Avatar
+1 on the 1000 leaves. Bend down the glovebox and it should run out in that general area.
Old Jul 29, 2008 | 09:38 PM
samson_420's Avatar
I did mine in about 30 Minutes. 15 minutes to clean out the crud behind the PCM, then 15 more minutes to route the wire.
Old Jul 29, 2008 | 10:13 PM
robsquikz28's Avatar
i did 2 of them in 40 mins and the second kit i made my own fan switch its stupid proof
Old Jul 30, 2008 | 03:54 AM
Joshiedoom's Avatar
Old Jul 30, 2008 | 04:02 PM
Formula413's Avatar
So true.
+1 on making your own switch, cost me like $5.
