Sponsored by: CARiD
Condensation on Driver Rear Tail Light
Old Aug 1, 2008 | 05:21 AM
corvet786c's Avatar
Default Condensation on Driver Rear Tail Light
I ve tried everything. Sealing the housing trying to find any leaks and water still gets in there. Does anyone know how to keep water out of the honeycomb style 98-02 rear brake light thanks.
Old Aug 1, 2008 | 08:58 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Take the light inside the house, hair dry the insides to ensure NO MOISTURE, then RTV the any space that allows air in, light bubs are a good place to start.
Let set for atleast 24 hours before putting it on the car.
Worse comes to worse, if its truely sealed, dunk it in a bathtub and see if any water is getting in.
Old Aug 1, 2008 | 09:00 AM
badazz99ta's Avatar
^^^sounds like a good idea. i got the same problem on my reverse light. so i will give this a try.
Old Aug 1, 2008 | 09:01 AM
beerwhiskeyjoe's Avatar
Drill holes in the bottom of the housing. No matter what you try, you aint gonna keep all the water out. Give it a place to vent/drain, so that way it doesnt eat away at the reflective stuff in the housing.
Old Aug 1, 2008 | 10:27 AM
1987firechicken's Avatar
What I did with my turn signal housings on the front I took them off and sealed up all the holes and then blew into it through the bulb hole to see where the air was coming out of. Put in sealant until air wouldn't escape anymore.
Old Aug 2, 2008 | 09:30 AM
sketterman's Avatar
Did anyone ever have any luck with permanately keeping the moisture out? I had that problem with my passenger tail light years ago and I tried everything with no luck. I ended up just replacing it.
Old Aug 2, 2008 | 07:48 PM
94'BLKBRD's Avatar
I would just drill small holes in the housing
Old Aug 5, 2008 | 02:09 AM
ls1tech.fan's Avatar
The first time I sealed mine it did not work, so I sealed it again and it's been fine since. Make sure you dry out all the water from inside.
Old Aug 5, 2008 | 07:06 AM
Internet Mechanic
Yup, he lives in FL so Im like take it in the house, hair dry it and since he has AC the humidity is VERY low.
