Sponsored by: CARiD
Overheating with GFX
Old Aug 6, 2008 | 02:13 PM
shaguar_red's Avatar
Default Overheating with GFX
I have a 96 LT1 camaro with Wings west ground effects, its overheating. I dont have the longer airdam. I was wondering if I cut out the plastic piece in the grill and removed the shield behind it to get direct airflow to the radiator, if this would help? I like this look and I will probably put a billet grill there anyway. Ive searched and searched and it seems the only info I find about cutting the grill are for FMIC installs. Id rather not get a longer air dam cuz I dont have much ground clearance as it is. Has anyone done this?
Old Aug 6, 2008 | 02:54 PM
needadvice's Avatar
If you're overheating while cruising on the highway there's nothing you can do except put the air dam back on....thats whats its there for.
If you're overheating during stop-and-go traffic i nthe city, it has nothing to do with the air dam.
Old Aug 6, 2008 | 02:55 PM
The air dam is still on. Its overheating while driving down the highway. The ground effects block flow to the air dam. Its a common problem with them. I was just wondering if cutting the grill out would help or make it worse.
Old Aug 6, 2008 | 04:12 PM
SparkyJJO's Avatar
cutting it out should help since it would allow more air... but screw the kit, I don't think they look all that great on these cars anyway and as you have found they can cause trouble too!
Old Aug 6, 2008 | 04:15 PM
Well I like the kit. LOL But you are right, it causes problems. I didnt know if cutting out the grill would affect the direct flow of air from the air dam. I know it will affect it some, but I wasnt sure if it would enough to hinder cooling.
Old Aug 7, 2008 | 11:10 AM
Craiggg's Avatar
Put a manual fan switch on it and turn your fans on all the time.
Old Aug 7, 2008 | 11:49 AM
cgroh89's Avatar
Could you get some aluminum and try to make a air dam that sits lower? Just a thought be fore you go cutting into stuff , Or you can get a pusher fan
Old Aug 7, 2008 | 12:18 PM
Yeah, thats what my next resort was. I didnt think about a pusher fan. That might be a good idea too.
Old Aug 7, 2008 | 01:26 PM
mrnorm_hemicide's Avatar
Yeah, that air dam is really the only way for air to be circulated up to the radiator on f-bodies.
