Sponsored by: CARiD
Trip Odometer Resets Itself
Old Aug 13, 2008 | 06:54 PM
my bandit's Avatar
Default Trip Odometer Resets Itself
some times when i clean my car i have the radio on (with the key turned back) for about 30 min. when i turn my car back on it has reset itself back to 0. is this normal or is something messed up?
Old Aug 13, 2008 | 07:08 PM
2001NBMZ28's Avatar
Low battery voltage on the '99 cars can reset the trip odo, sometimes accompanied by the gauges sweeping on startup. If you didn't have the stereo on I'd suspect the battery and have it load tested.
Old Aug 13, 2008 | 07:22 PM
samson_420's Avatar
Either too low of voltage or a bad connection from the battery on?
I would check the voltage and check for corosion around the battery cables.
Old Aug 13, 2008 | 07:29 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Battery is going/gone/on its way out....Go get yourself an OPTIMA RED TOP.
Old Aug 13, 2008 | 08:45 PM
keliente's Avatar
been there, done that, replaced the battery and it's perfect now.
Old Aug 14, 2008 | 10:18 AM
Danny2tek's Avatar
X2
Old Aug 14, 2008 | 10:53 AM
keliente's Avatar
Originally Posted by Mustang5.Ohater
X2
1999 birds unite!!!
Old Aug 14, 2008 | 07:53 PM
ZexGX's Avatar
Funny! I have an optima red top and have the same problem. The issue on mine is that it corrodes at the + terminal... Even with a Red Top. I'm going to have to disconnect it, clean out both ends and then prep it with an anti-corrosion agent to try and resolve the issue.
Old Aug 14, 2008 | 10:15 PM
my bandit's Avatar
the thing is i never have trouble starting it up or anything. the only thing ive ever noticed is that sometime when i just crank it up i will see the volt guage go up as the rpm's rise.
i might have to get a new one anyways b/c i might get a new system
Old Aug 14, 2008 | 10:27 PM
Danny2tek's Avatar
Mine started just fine too , but once I replaced the battery the problem with the odometer/gauges went away.
