Sponsored by: CARiD
battery or alt.
Old Aug 17, 2008 | 08:52 PM
hevymetalg's Avatar
Question battery or alt.
if i leave just the radio on for 25min the car wont start with out a jump? but it will start every day just fine if i just drive and turn everything off, im thinking i need a new battery?
Old Aug 17, 2008 | 09:38 PM
1987firechicken's Avatar
Yup sounds like your battery is having a hard time holding a decent charge. Replace it and you should be set to go.
Old Aug 17, 2008 | 09:41 PM
2_wacko's Avatar
Check the volts on your gauge if they are not dropping its your battery.
Old Aug 17, 2008 | 10:29 PM
samson_420's Avatar
Most likely the battery, but check to see if it drains on it's own.
Let it sit for a day or so, then check the voltage. It should be at least 12.3 or a bit more.
Old Aug 18, 2008 | 04:12 AM
Black 99 Bird's Avatar
Yep, battery.
